18 years agoDE2 TV Decoder
Hi, I've been trying to make the TV Decoder design work on the DE2 board, and haven't been able to! I've tried both versions (PCB 1.x and 2.x) and neither worked. I remember I had tried it long...
15 years agoJust a suggestion...
Did you connect all video input boards together in parallel, without an input video buffer distributor ? If you did it, I can see how the video signal is in degrade. Cheers. Alberto.
