18 years agoDe2_nios_device_led
Hello everyone, I'm trying to get DE2_NIOS_DEVICE_LED demonstration working. The problem is when I try to install the d12test.inf driver, windows says "the wizard could not find a better match ...
17 years agoDear Friend,
I solved this problem by using 2 USB cables. Before you programming to DE2 board, you make sure 2 USB cables (USB blaster and USB device) to connect your host computer. It will be solved your problem Regards TZ
