18 years agoDe2_nios_device_led
Hello everyone, I'm trying to get DE2_NIOS_DEVICE_LED demonstration working. The problem is when I try to install the d12test.inf driver, windows says "the wizard could not find a better match ...
17 years agoDear Friends,
I also had a similar experience.I could not install the ISP1362 river for one month. I solved the problem recently. You try connecting both USB cables( Blaster and Device ) from the begining. Also do this while building the project.after build is complete rmove the USB cable from Device port aand run the C program, once u get a message chip ID XXX, u connect back the Device USB, your DE2 board will be detected by the OS as a new device and it will prompt you to install the driver. I hope this will help you... Regars, Mahesh
