15 years agoDE2_NIOS_DEVICE_LED usb driver
Hi, I load the DE2_NIOS_DEVICE_LED.sof programming file. Build and run the project; Plug in the USB cable on the USB device port on the DE2 board The host computer will need install...
15 years agoWhat OS are you using? Windows or Linux?
If you are using windows, go to folder Nios folder and run nios script file and load the .elf file to run
