16 years agoDE2 Lab 4, Part 4 (VHDL) - Digital Logic
I'm new to VHDL and FPGAs but need to learn how to program with it for my graduate studies. I decided to try out the tutorials and labs on Altera's web site to get a start and have managed to work my...
16 years agoI'm not sure how this would synthesize, but you should make your process clocked instead of depending on the counter. What you are describing here is to keep on increasing num as long as the count vector is at that value, not just increase it once when you reach the value. This code will probably generate a combinatorial loop that will give unpredictable results.
So the first rule is to make your process dependent on the clock only:
PROCESS (CLOCK_50) And then in the process, only accomplish what you want on the rising edge of the clock
BEGIN
IF rising_edge(CLOCK_50) THEN
IF (Count = "10111110101111000010000000") THEN
Num <= Num + '1';
Clear <= '1';
IF (Num > "1001") THEN
Num <= "0000";
END IF;
ELSE
Clear <= '0';
END IF;
END IF;
END PROCESS;
Please note that doing it that way will add one cycle latency between the counter and your process. The value you will see in the 'Count' variable will be the counter output from the previous clock cycle. You may need to subtract one to your maximum counter value to have the exact number of cycles. I would also recommend to forget about ieee.std_logic_unsigned.all and use ieee.numeric_std and the unsigned/signed types instead.
