17 years agoDE2 crystal clock pulse
Hi All, I need to generate a square wave from the DE2 board. I already assigned the DE2 board internal, 50MHz clock to a NOT gate and its output to a GPIO pin and read using an oscilloscope. how...
17 years agoI assume, that most of the distortion is caused by your oscilloscope probe. Actually a 50 MHz squarewave can't be exactly acquired without an active probe or a resistive high frequency probe. In addition, the IO pin drive strength may be reduced to match the trace impedance.
