17 years ago
DE2 board VGA Dispaly
Hello All,
I am trying to use the board's SRAM to store an image and dispaly it on the screen.
I designed a project using QuartusII and was able to manage the
VGA dispaly timing. I used a reference design from John Loomis Webpage.
http://www.johnloomis.org/digitallab/vgalab/vgalab3/vgalab3.html which
is very helpful and nice. However, I am having a problem in dowloading the
raw image file to the SRAM. My question is:
How can I get a typical 640 X 480 bitmap image to be stored in the SRAM?
I tried to use Terasic ImgConv, but it doesn't work :(
I appricate your help.
    Hello thanks for answering, actually i have a code that i found on rockets boards "VIP camera", it works fine. I tryed to add an LCD to whatch the video output but i couldn´t. I´m new on video processing and i got a new more question: do you know how can i get a image frame capture or how can i get access to the RAM memory and extract an image? Thanks a lot.
    Regarding access, I have not done this, but I would imagine you probably need to write a device driver or use a device driver (like maybe what is in my-first_hps-fpga).
    Which lcd are you using? The Ardunio ones typically use a spi interface, but maybe you are going Benheck style and connecting something you salvaged.
