18 years agoDE2 board VGA Dispaly
Hello All, I am trying to use the board's SRAM to store an image and dispaly it on the screen. I designed a project using QuartusII and was able to manage the VGA dispaly timing. I used a...
15 years agohi,BTXSistemas.I tried your code about 320x240 24 bit RGB image.
However,it't didn't work My topic is:i want to display 256x256 x 24bit RGB, i use DE2 control panel to send directly my data of image to Sram DE2 board.However, i can't display the image from Sram to Vga...i need your help ..May be you can resend your another code or explain more carefully for me the way to solve that problem thanks alot --- Quote Start --- Hi. Here´s some code to try the 320x240 image. Let me know if it was usefull. --- Quote End ---
