18 years agoDE2 board VGA Dispaly
Hello All, I am trying to use the board's SRAM to store an image and dispaly it on the screen. I designed a project using QuartusII and was able to manage the VGA dispaly timing. I used a...
17 years agoSorry Monish If I understood correct your question, you have a gray scale image in the SRAM.
So, you couldn't generate a color image, but, you can get each pixel of the SRAM and then, assign VGA_R = image_pixel, assign VGA_G = image_pixel, assign VGA_B = image_pixel. You'll have only eight bits, but if first you shift the data two times left, you'll have a variable of 10 bits to assign to the VGA R,G,B wires. Your data will look like this: 10'b 1111111100 for a maximun pixel bright, so 256 differents levels, for this 10 bit D/A DE2 vga chip.
