10 years agoDE2 Board, design loads but doesn't run
Hey Currently trying to get my traffic lights system to run on the Altera DE2 board. Its simulated and all working in the software however when i program it to the board it shows the initial ...
10 years agoYeah, im having this problem with numerous designs.
Library ieee; Use ieee.std_logic_1164.all; Entity trafficlights is Port (SenA, SenB, Clk, Init: in bit; Lights: out bit_vector (5 downto 0)); End trafficlights; Architecture moore of trafficlights is Type state_type is (S0, S1, S2, S3, S4, S5, S6, S7, S8, S9, S10, S11); Signal state: state_type; Begin Process (Clk, Init) begin if Init ='1' then state <= S0; elsif Clk= '1' and clk'event then case state is when S0=> if SenA ='0' and SenB ='0' then state<=S1; elsif SenA ='0' and SenB ='1' then state<=S4; elsif SenA ='1' and SenB ='0' then state<=S0; elsif SenA ='1' and SenB ='1' then state<=S1; end if; when S1=> if SenA ='0' and SenB ='0' then state<=S2; elsif SenA ='0' and SenB ='1' then state<=S2; elsif SenA ='1' and SenB ='0' then state<=S2; elsif SenA ='1' and SenB ='1' then state<=S2; end if; when S2=> if SenA ='0' and SenB ='0' then state<=S3; elsif SenA ='0' and SenB ='1' then state<=S3; elsif SenA ='1' and SenB ='0' then state<=S3; elsif SenA ='1' and SenB ='1' then state<=S3; end if; when S3=> if SenA ='0' and SenB ='0' then state<=S4; elsif SenA ='0' and SenB ='1' then state<=S4; elsif SenA ='1' and SenB ='0' then state<=S4; elsif SenA ='1' and SenB ='1' then state<=S4; end if; when S4=> if SenA ='0' and SenB ='0' then state<=S5; elsif SenA ='0' and SenB ='1' then state<=S5; elsif SenA ='1' and SenB ='0' then state<=S5; elsif SenA ='1' and SenB ='1' then state<=S5; end if; when S5=> if SenA ='0' and SenB ='0' then state<=S6; elsif SenA ='0' and SenB ='1' then state<=S6; elsif SenA ='1' and SenB ='0' then state<=S6; elsif SenA ='1' and SenB ='1' then state<=S6; end if; when S6=> if SenA ='0' and SenB ='0' then state<=S7; elsif SenA ='0' and SenB ='1' then state<=S6; elsif SenA ='1' and SenB ='0' then state<=S10; elsif SenA ='1' and SenB ='1' then state<=S7; end if; when S7=> if SenA ='0' and SenB ='0' then state<=S8; elsif SenA ='0' and SenB ='1' then state<=S8; elsif SenA ='1' and SenB ='0' then state<=S8; elsif SenA ='1' and SenB ='1' then state<=S8; end if; when S8=> if SenA ='0' and SenB ='0' then state<=S9; elsif SenA ='0' and SenB ='1' then state<=S9; elsif SenA ='1' and SenB ='0' then state<=S9; elsif SenA ='1' and SenB ='1' then state<=S9; end if; when S9=> if SenA ='0' and SenB ='0' then state<=S10; elsif SenA ='0' and SenB ='1' then state<=S10; elsif SenA ='1' and SenB ='0' then state<=S10; elsif SenA ='1' and SenB ='1' then state<=S10; end if; when S10=> if SenA ='0' and SenB ='0' then state<=S11; elsif SenA ='0' and SenB ='1' then state<=S11; elsif SenA ='1' and SenB ='0' then state<=S11; elsif SenA ='1' and SenB ='1' then state<=S11; end if; when S11=> if SenA ='0' and SenB ='0' then state<=S0; elsif SenA ='0' and SenB ='1' then state<=S0; elsif SenA ='1' and SenB ='0' then state<=S0; elsif SenA ='1' and SenB ='1' then state<=S0; end if; end case; end if; end process; Process (state) Begin Case state is When S0 => (Lights) <= "001100"; When S1 => (Lights) <= "001100"; When S2 => (Lights) <= "001100"; When S3 => (Lights) <= "001100"; When S4 => (Lights) <= "001100"; When S5 => (Lights) <= "010100"; When S6 => (Lights) <= "100001"; When S7 => (Lights) <= "100001"; When S8 => (Lights) <= "100001"; When S9 => (Lights) <= "100001"; When S10 => (Lights) <= "100001"; When S11 => (Lights) <= "100010"; end case; end process; end Moore;
