16 years agoDE2 board and nichestack
Hello, I have been battling with this problem for quite some time so any help will be appreciated!
my project is working correctly on Nios IDE 6.0. Because lwip and the code about DM9000a for lwip . But now i will work on Nios IDE 9.0. There is not lwip. nichestack is the new protocol. So DM9000A can't work. is there the code about DM9000a for nichestack? Or what should i do to make it can work? and my projeck work on ucosii. thanks very much!2 Replies
yoo can replace it with a lower version.
Altera have kept uCOS/OS-II from Micrium as their preferred RTOS, but have dumped open-source LWIP in favour of Nichestack from Interniche.
Check out my solution which uses the latest socket server reference design from Altera and supports Nichestack on the DE2 board: http://www.alteraforum.com/forum/showthread.php?t=24020
