16 years agoDe2-70 Wİth D5m Camera Realtime Image Processing
I am working with the DE2-70 dev kit and the D5M camera, and i would like to implement an image processing algorithm to this dev kit demo file which called DE2_70_D5M_XVGA.qpf...
i am not so much familar to verilog or quartus.... if i would like to add a median filter from megacores, which steps should i follow..? esspecially i would like to learn should i connect to mCCD_DATA wire to median filter's input, from the main file DE2_70_D5M_XVGA.v.. or should i connect which variable?1 Reply
merhaba ozcelik
hw olarakmı imaga processing yapmak istiyorsunuz. bu genel bir kavram. neyi kontrol istediginizi yazarmısınız. TR:)
