15 years agoDE2-70 Flash
I am working on DE2-70 now and trying to program ELF into the onboard flash. Questions, 1. In SOPC builder, CFI + Avalon-MM Tristate Bridge, 16 bit WORD MODE. The address bus generates ...
15 years ago1) That is normal.
For 16bit connection, you do not need the lowest address bit, just don't connect it. Some flash manufacturers commonly use the same pin for data[15] and address[0], as they are never used at the same time.
