15 years agoDE2-70 Default help
Hey guys im new at this. i recently bought a DE2-70 board but whenever i start the board it doesnt do that default demo thing (where the lights flash, the numbers change, lcd says welcome) i know its not a big deal but any idea how i can permanently load the default demo into the board? i tried setting the board to PROG and then using programmer to load it but it doesnt work (however it loads when its on RUN but it is only temporary since itll get erased when i turn it off). thanks
1 Reply
Don't over any FPGA image into EPCS. So when you witch to RUN then power up, the default image will load.
