15 years agoDE2-70 - Exit Code 1h
I'm repeatedly encountering exit code 1h when trying to use the DE2_70_Camera Camera Utility V1.1.0. When I click 'Download Code', the error message: "Execute(<MyPath>\NiosDownloadBatch.bat) fail. ...
15 years agoAre you running the camera utility as an admin? Not doing so can cause issues talking to hardware.
Do you have these variables in System\Environment? sopc_kit_nios2 c:\altera\10.1sp1\nios2eds quartus_rootdir c:\altera\10.1sp1\quartus (Obviously you'll need to change 10.1sp1 to whatever your version of quartus/nios named those folders) It might be worth trying Terasic's tech support as well: support [at] terasic.com I ended up fixing the issue with info from these forums, but they respond quite quickly and might have some other ideas as well.
