14 years agoDE2-70 - DE2_70TV demonstrator is not working
Hello, I have a Terasic DE2-70 board and I am trying to run the demonstrator DE2_70TV. The .sof file that comes with the CD and the demonstrator downloaded internet is working perfectly, but if...
14 years agothere are in a file DE2_70_TV.sdc
you can add from settings, assignments • In Timing Analysis Settings, select Use TimeQuest Timing Analyzer during compilation. • In TimeQuest Timing Analyzer add the time constrains file. if then check the report of timing after compiling also if you have problem read a tutorial about TimeQuest, it is short :)
