15 years agoDE2-115 with HSMC_ADA from terasic
Hello, I was thinking about buying a DE2-115 and an HSMC_ADA from terasic. How do I know the DE2-115 can handle the amount of data coming in and out of the HSMC_ADA? How do I know wha...
15 years ago --- Quote Start --- I was thinking about buying a DE2-115 and an HSMC_ADA from terasic. How do I know the DE2-115 can handle the amount of data coming in and out of the HSMC_ADA? How do I know what type of connection is between the FPGA and the ADA board. I can understand that it is HSMC but is it an LVDS signal? The DE2-115 has an EP4CE115 FPGA. The HSMC_ADA has two 14-bit ADCs and two 14-bit DACs running at 65 MSPS and 125 MSPS, respectively. Each ADC and DAC bit has their own pin. --- Quote End --- All of this information should be in the resources provided by Terasic. http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=67&no=278 Why don't you read that information first, and then come back with specific questions. Cheers, Dave
