13 years agoDE2_115 SD_Card Audio Player
Hi all, I want to modify the DE2_115 SD_Card Audio Player demo project for my own project and add the audio recording function to it. Basically it is like combining the Audio Player demo and th...
13 years agoI have tried compiling the DE2_115_SD_Card_Audio_Player project in Quartus 2. Then clicked on File -> Create/Update -> Create Symbol Files for Current File. It said Symbol file created successfully but I can't find it in the project directory.
After compilation, it shows DE2_115_SOPC:DE2_115_SOPC_inst under the main project in the Project Navigator. Double clicking on it opens the SOPC builder for the project. I tried generating this system again in the SOPC builder but it gives the following errors: Warning: Entity "altpll" obtained from "altpll.v" instead of from Quartus II megafunction library Error: Node "c0" is missing source File: C:/Users/.../AppData/Local/Temp/alt5789_2303333993077008292.dir/0027_sopcqmap/altpll.v Line: 243 Error: Node "c1" is missing source File: C:/Users/.../AppData/Local/Temp/alt5789_2303333993077008292.dir/0027_sopcqmap/altpll.v Line: 244 Error: Node "c2" is missing source File: C:/Users/.../AppData/Local/Temp/alt5789_2303333993077008292.dir/0027_sopcqmap/altpll.v Line: 245 Error: Node "c3" is missing source File: C:/Users/.../AppData/Local/Temp/alt5789_2303333993077008292.dir/0027_sopcqmap/altpll.v Line: 246 Error: Node "locked" is missing source File: C:/Users/.../AppData/Local/Temp/alt5789_2303333993077008292.dir/0027_sopcqmap/altpll.v Line: 248 Error: Node "readdata[0]" is missing source File: C:/Users/.../AppData/Local/Temp/alt5789_2303333993077008292.dir/0027_sopcqmap/altpll.v Line: 251 Error: Node "readdata[1]" is missing source File: C:/Users/.../AppData/Local/Temp/alt5789_2303333993077008292.dir/0027_sopcqmap/altpll.v Line: 251 Warning: Quartus II 32-bit Analysis & Synthesis was unsuccessful. 7 errors, 2 warnings Error: Peak virtual memory: 313 megabytes Error: Processing ended: Mon Mar 25 14:45:39 2013 Error: Elapsed time: 00:00:01 Error: Total CPU time (on all processors): 00:00:01 I just want to be able to modify the main.c file in NIOS 2 - Eclipse and use it for my own project.
