De2-115 remove the default project
- 2 years ago
The DE2-115 is a pretty old board, around since 2012; I got mine back in 2015 and it uses an EPCS64 device for program storage.
I use QuartusII 16.0 for development it it works exactly as the documentation specifies.
When did you get your board, and what version of Quartus are you using?
Are you aware of: https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=165&No=502#contents
If you look here:
The link to the user manual is available as a PDF file.
On pages 12-13 section 2.3 it describes the behavior of the default program in EPROM provided on a new board.
The welcome message you indicate is written to the LCD. And the sound behavior you described is present.
So if you continue to see that message you are not overwriting the default program in EPROM.
I would suggest that you download the support CDROM from the TerAsic site and follow their examples.
