8 years agoDE2 - VGA Draw Text generate Stack Overflow on quartus_map.exe while compiling
Hello community, I try to text information to VGA to display it on screen. Everything works fine. I convert characters of a font to 2D integer position xy-array and read it out in a loop to mak...
8 years agoHi Martin,
1.If you can't find the board in newer Quartus version,You should add it from design store check the image. 2.Due to a problem in the Quartus II software version 14 and earlier, you may see this error when you compile a design containing a long series of LUTs with no registers. Or Increase the stack size of OS. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) https://www.alteraforum.com/forum/attachment.php?attachmentid=14474
