8 years agoDE2 - VGA Draw Text generate Stack Overflow on quartus_map.exe while compiling
Hello community, I try to text information to VGA to display it on screen. Everything works fine. I convert characters of a font to 2D integer position xy-array and read it out in a loop to mak...
8 years agoHello Anand,
thank you for your response. I use Version:14.1.0 Build:186 Edition: Web Edition the problem I have is that newer versions do not support Cyclone IV E (EP4CE115F29C7) Boards. I there a way to use newer versions with older boards? To your second point, how could I realize that? Greetings Martin.
