8 years agoDE2 - VGA Draw Text generate Stack Overflow on quartus_map.exe while compiling
Hello community, I try to text information to VGA to display it on screen. Everything works fine. I convert characters of a font to 2D integer position xy-array and read it out in a loop to mak...
8 years agoHi
1.Which Quartus version your are using?Try with latest Quartus version. 2.To work around this problem, reduce the number of consecutive LUTs between registers. Alternatively try a different operating system as the maximum stack size is defined by the operating system. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
