11 years ago
DE1 Altera UP Flash Memory IP Core, No CFI table found & Error code: 8
I've been trying to get the on board flash memory working with the DE1 using the UP flash memory IP core but I can't get it working. Firstly, I'm using the DE1 Media computer instead of my own QSYS implementation (which gave the same error) so I'm under the impression that it should work without much tinkering. I read the relevant documentation as well and the requirements seem to be met in the example design.
However when I try to use the flash programmer through Eclipse I get a No CFI table found (at the address of the flash memory) along with an error code 8. After reading through the forum it seems like this is a common problem but mostly with external flash memory. I'd appreciate any help on the matter if someone happens to read this. I'm using Quartus 64 bit 13.0.1 on a Windows 8 system. Thanks in advance.
Ammar
    One more question: have you ever tried zipfs with subfolder? Like read file at "/mnt/rozipfs/subfolder/text.txt"?
    I've tried and it was failed.
    I'm afraid I haven't tried it and I'm not sure if it would work. You may have to change the mount point to that subfolder. If you figure it out please do share.
