12 years agoDE1 Altera UP Flash Memory IP Core, No CFI table found & Error code: 8
Hi, I've been trying to get the on board flash memory working with the DE1 using the UP flash memory IP core but I can't get it working. Firstly, I'm using the DE1 Media computer instead of my ...
12 years agoMaybe the reason zipfs did not run is the memory. I wonder why, it sounds so ridiculous since I use SDRAM instead of On-chip memory, the system works fine when other parameters are kept unchange :))
I'm done with zipfs now, thank you again Ammar, for your invaluable help :D
