12 years agoDE1 Altera UP Flash Memory IP Core, No CFI table found & Error code: 8
Hi, I've been trying to get the on board flash memory working with the DE1 using the UP flash memory IP core but I can't get it working. Firstly, I'm using the DE1 Media computer instead of my ...
12 years agoHey. Well the flash on my board was exactly the same as the document since I'm using a DE1 board. When you add the tristate controller to QSYS and look at its options you can see some available presets. There's a couple for AMD as well. If your flash is one of those, then you can use it directly. If it's not then you'll probably have to use datasheet for your flash to get the information. There's also a chance that someone else has already gotten the information out if the flash is popular.
