12 years agoDE1 Altera UP Flash Memory IP Core, No CFI table found & Error code: 8
Hi, I've been trying to get the on board flash memory working with the DE1 using the UP flash memory IP core but I can't get it working. Firstly, I'm using the DE1 Media computer instead of my ...
12 years agoWell make sure you set the generic tristate controller according to the flash memory on your board. My goal was also to get the zipfs working and setting up the flash correctly was the main issue. After that it was relatively straightforward. Good luck.
