9 years agoDE1, Altera Monitor Program 15.1 and SD Card Boot issue
We are developing a baremeral application on DE1-SOC board using HPS only and Altera Monitor Program 15.1. The project has to access SD Card and it works well so far. But my problem is that, whenever I compile and try load the project into board, it gives error about "linux booting.." if our empty SDCard is plugged into MMC socket. And I had to unplug the card for proper project loading. This is annoying, I don't want to remove sdcard from the slot each time I need to recompile and load the project. How to disable sdcard linux boot option at power up? Thanks.1 Reply
Could you help me out? I am trying to achieve the same thing but I cannot get SD card to work.
