15 years agoDE0: Nios 2 with custom logic and PIO.
Hi, I'm just getting started with the DE0-board. (Cyclone III). My goal is to have a Nios 2 soft core processor together with UART. I also want the Nios processor to act master on the avalon bus c...
15 years agoHave a look at chapter 10 of that document (http://www.altera.com/literature/ug/ug_sopc_builder.pdf).
For a simple compenent like yours, you should just need a 'write' signal (std_logic) and a 'writedata' signal (std_logic_vector) on your avalon slave interface. They are both inputs, and when write is '1', read the contents from 'writedata'. You should also have a clock input interface (clock and reset signals) and a conduit interface for the PWM signal that you generate.
