ABerg28
5 years agoDE0-NANO Quartus Lite 19.1 NIOS II Project error
I'm dead in the water now. I've been following a YouTube tutorial to build a simple adder program to run on the NIOS II in a Cyclone IV on a DE0-NANO board.
https://www.youtube.c...
EricMunYew_C_Intel
5 years agoYou can install below manually.
1. install WSL for windows i. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/n2sw_nii5v2gen2.pdf (chapter 2.1) Note: Windows 10 build version 16215.0 or higher is the recommended operating system version. ii. After installation has successfully completed, launch Ubuntu 18.04. iii. Install additional distro packages required for Nios II EDS using the following commands: a. sudo apt install wsl b. sudo apt install dos2unix c. sudo apt install make
before"sudo apt install wsl" run: sudo apt-get update
2. install nios2 eclipse folder |
