15 years agoDaisy Chain DE2 boards
Hey everyone! First off, I'm new here, so if this is in the wrong section, please move it. I am attempting to find a way to daisy chain multiple DE2 boards together in order to pass synchroniza...
15 years agoQuite honestly, distributing clocks and resets through the RS-232 transceivers looks like a bad idea.
The DE2 has a external clock input, using a SMA connector. I suggest you use that one for distributing clock to all 3 DE2 boards. Then work into fitting your remaining needs into the 40 pin headers. Ie, I suggest you put a debounced push button on your daughter card to generate the RESET and feed it back to the DE2 boards though a pin in one of the 40 pin headers.
