11 years agoD5M Camera: VHDL Code for images acquisition on DE2-70 Board
Hi to everyone! I would like just a block for acquisition in VHDL language, because i am programming in VHDL, and the camera code is in Verilog . Thanks
11 years ago --- Quote Start --- Hi to everyone! I would like just a block for acquisition in VHDL language, because i am programming in VHDL, and the camera code is in Verilog . Thanks --- Quote End --- Hello cdnv, Verilog and VHDL is just a language to descript your module. I suggest you read up some syntex on verilog and re-synthesis it to VHDL. Be mindful to verify your RTL and also test your module using the test-bench. This will ensure your synthesis is correct. Please correct me if I am wrong. Cheers, - CrimsonLion
