18 years agoCyclone II starter dev kit,DE1, Audio HELP!
Hi Everyone, I'm using the DE1 FPGA board. I'm trying to pass a signal from the mic to the speaker using the UP IP. The zip file and related pdf can be found here: http://www.altera.com/educat...
14 years agoHi! I am having the same problem . Can you revert back with the solution you found .
