15 years agocyclone 2 LPM_COUNTER begginer problem
hello im new to the whole fpga programming scenario and im trying to implemnent a niosII processor on a cycloneII FPGA(on a DE2 board). in addition to my niosII processor i require some sort of ad...
15 years ago --- Quote Start --- Please PLL, not LPM_COUNTER --- Quote End --- @waiyung Have u generated 100 Hz from 50 Mhz on DE2 by PLL? PLL input and output frequency min and maximum frequency ranges depend on the FPGA that u select and multiplication/division factor that specs says about it. So i dont know if PLL can generate 100 Hz from 50 MHz for DE2 board. @normad To know better PLL,best possible thing is to read PLL IP core guide from avalon documents. Even if you will not able to understand at once,it will help you a lot.
