custom ip core
hi Anand,
the txt file I attached "myRossler.vhd" provide as output 3 signalz x,y and z of 32 bit,
I just want you please to show me how to use your example to make these signals x,y,z
visible in eclipse.
because in the project you attached "myRossler.v" used reg32.v to output Q_export.
It is ineed visible in eclipse by the name MYROSSLER_0_BASE but doesnot give any of the 3 signals x, y or z.
can you please just tell me how to do we with "myRossler.vhd"
WE ARE NOT HERE FOR CREATING PROJECT
It is ineed visible in eclipse by the name MYROSSLER_0_BASE but does not give any of the 3 signals x, y or z.
>>It's Qsys IP instance name. You have to modify myRossler.v & reg32.v as per your requirement.
>> You will not see any signals in eclipse, You can communicate using base address check system.h for base address.
Refer below link and try to understand how PIO communicated using base address.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/tt/tt_my_first_nios_sw.pdf
Anand
