rkaib
7 years agocustom ip core
I am using de2-115 withquartus. I have created an IP core in the platform designer, addede it to my quartus project main vhdl file, compil it but it is not included whenI open eclipse. how to explo...
AnandRaj_S_Intel
7 years agoHi,
Your myRossler IP dose not have any logic or avalone interface.
Add avalone interface and check the eclipse.
Thanks for update
I don't have vga subsystem to compile your design.
Anand
rkaib
7 years agohello anand,
I have made some change as follows:
- in Platform Designer: in my IP ("myrossler"), I have added an avalon memory mapped slave with (avalon_slave_read[1],)avalon_slave_readdata[8],avalon_slave_write[1],avalon_slave_writedata[8]),
- In quartus: in DE2_115_computer.vhd, in component and port map added my_rossler_conduit_end_read1 : ou std_logic_vector (31 downto 0); for read1,read2 and read3, then I connected them with myrossler_read1, myrossler_read2 and myrossler_read3, then I compiled.
My problem is: 12002 Port "avalon_slave_read" does not exist in macrofunction "myrossler_0"
12002 Port "avalon_slave_readdata" does not exist in macrofunction "myrossler_0"
12002 Port "avalon_slave_write" does not exist in macrofunction "myrossler_0"
12002 Port "avalon_slave_writedata" does not exist in macrofunction "myrossler_0".
just to remind you "myrossler" is a custom IP that has inputs clk and rst and outputs 3 32 bits signals that I want to exploit
Thank you very much anand
