CSV import to assignment editor help
We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
- masterboyle5 years ago
I attached the files above that I think show that the problem is not just in the column naming. My columns are named the same as the "good" file, and will not import.
- RichardT_altera5 years ago
Try to open the "bad" file and save the file as in CSV (Comma delimited) (*.csv) format. I try to save the "good" file to CSV UTF-8 (Comma delimited) (*.csv) instead and the import assignment does not work.
Let me know if it helps.
Ok I will try that.
