13 years agoCreate new component DM9000a
Hi im trying to do tcp/ip packet sending project between FPGA and PC. I wanted to add DM9000a component but, it is unavailable in list. So i think i need to create a component. Im thinking of adding the DM9000a.v and DM9000a_IF.v from the DE2_NET demo from the cd-rom, unfortunatly it is more than that. There are pin assignments which im not sure how...
Is my method correct and are there any suggestions on how i should proceed with this. Should i build my own or just edit from the existing?1 Reply
Hi, I have the same problem at the moment, did you find any solution in the meanwhile?
