Lida8
4 years agoCould you check if EP4CE6F17C8N
Problem description: PROBLEM FAILURE PHENOMENON: ICT test BGA open circuit, FT test can not write Number of failures: 32 pcs Defective rate: 32/1200 = 2.67% Without any problem from exterior,X-...
YuanLi_S_Intel
4 years agoHi, seems like this is duplication of case 05453810. We will continue to support you on 05453810.
