TimSch's avatar
TimSch
3 years ago
Controller IP for DE10-Lite SDRAM
I'm having trouble to initialize the external SDRAM on the DE10-lite board. I tried to use the SDRAM Controller Intel FPGA IP which was available for free in qsys until Quartus 20. Now it seems not...
  • AdzimZM_Altera's avatar
    3 years ago
    Hi Tim,
    Please find my answer in points below.
    "What do you mean by "need to use own design to interface with the SRAM devices"? I thought that the IP would be the interface to communicate with my SDRAM. What am I getting wrong here?"
    • Yes the IP will create a module or design to interface with the memory device.
    • But in this case, the MAX 10 device has it's own supported IP for memory devices and it's limited to memory protocol.
    • So in this case, you need to create your own memory design or use some example designs available from the board vendor.
    "By example design you mean the "SDRAM_RTL_Test" in the Demonstrations directory aren't you? That's a great idea.
    To be honest I'm not very familiar with verilog, I only used VHDL yet so I was hoping for some VHDL boilerplate."
    • Yes the example design from Demonstrations directory.
    • Maybe you can use the converter to convert Verilog code to VHDL.
    "Am I right that - if I would work in verilog - I could simply copy the "Sdram_Control" entity and use it as sdram controller in other projects? Do you know if I have to consider something before using it in my own design? (I would probably try to translate it to VHDL and use it then)."
    • Yes I think you can copy the design into your design and make the connection similar to example design.
    • The parameter should be matched with the SDRAM device already.
    Adzim
