Controller IP for DE10-Lite SDRAM
- 3 years ago
Hi Tim,
Please find my answer in points below.
"What do you mean by "need to use own design to interface with the SRAM devices"? I thought that the IP would be the interface to communicate with my SDRAM. What am I getting wrong here?"
- Yes the IP will create a module or design to interface with the memory device.
- But in this case, the MAX 10 device has it's own supported IP for memory devices and it's limited to memory protocol.
- So in this case, you need to create your own memory design or use some example designs available from the board vendor.
"By example design you mean the "SDRAM_RTL_Test" in the Demonstrations directory aren't you? That's a great idea.
To be honest I'm not very familiar with verilog, I only used VHDL yet so I was hoping for some VHDL boilerplate."
- Yes the example design from Demonstrations directory.
- Maybe you can use the converter to convert Verilog code to VHDL.
"Am I right that - if I would work in verilog - I could simply copy the "Sdram_Control" entity and use it as sdram controller in other projects? Do you know if I have to consider something before using it in my own design? (I would probably try to translate it to VHDL and use it then)."
- Yes I think you can copy the design into your design and make the connection similar to example design.
- The parameter should be matched with the SDRAM device already.
Adzim
Hi Tim,
The MAX 10 device does supported DDR3, DDR3L, DDR2, and LPDDR2 SDRAM.
These are the IPs available in Quartus for MAX 10 device.
Link for reference: https://www.intel.com/content/www/us/en/docs/programmable/683658/current/external-memory-interface.html
It's does support SRAM but need to use own design to interface with the SRAM devices.
That's why you don't find the SDRAM IP in the Quartus.
There is an example design in the resources section of the DE10-Lite Board.
You may start to test with that design.
Adzim
Hi Adzim,
I must admit that I don't understand your answer completely, but I'm a complete beginner with (SD)RAM.
Iassumed that the SDRAM mounted on the board wouldn't be "DDR", so I thought I needed some other Controller IP.
Tim
