13 years agoconnecting DE1 cyclone II board to ethernet port in PC
Hi i am currently doing my final year project, which is remote video surveillance using FPGA de1 board. A camera will capture the video and transfer data to fpga, and from fpga it will send data to p...
13 years agoHi, mohamad .. I am also doing the same project on DE1 board and i want the LAN port. but it is not available on the DE1 board itself. IF you had done it as per the suggestions, then what is the resultfor that.
My project modules are: 1) To port nios2 softcore processor on the de1 board. 2) To install the OS(Compatible with de1) 3) To create an application on the above platform. Can you suggest me what new i can do in this application? IF any suggestions are there then please tell..
