12 years agoconfiguring SPI on SOPC
hello, I am trying to configure DE2 board as a Master and connect device(s) to it via SPI. DE2 -------> Device(s) In SOPC, do I include "SPI (3 wire serial)" from the library or "Avalon-ST Se...
11 years agoHello,
I happen to be doing the same thing but am using Qsys instead of SOPC. To answer your questions: 1. Yes I used the SPI (3 Wire) interface. 2. I used pins on the GPIO_0 (JP1) connector to connect the SS, MISO, MOSI and SCLK pins of the external device. Since MISO is an input (for the Nios II) and MOSI in an output, you need to rename DE2.qpf pin assignments so that they are no long GPIO_0[n] - since signals in the same bundle cannot be inputs and outputs. Otherwise simply assign the Nios exports from the SPI to pins on the GPIO_0[n] pins and then physically connect these pins to the correct pins on the device. 3. I found the function on this page somewhat useful - http://www.alterawiki.com/wiki/spi_core - you don't need to use the interrupts, just the bit that calls the HAL function alt_avalon_spi_command(). This driver is very rudimentary by the way - trying to get my students to build on it a bit in the lab.
