StefanoC
7 years agocompile the ADC source C file into ELF
I am experimenting the ADC module of the DE1-SoC. I have downloaded the DE1-SoC_v.5.1.3_HWrevF.revG_SystemCD and I can successfully run the DE1_SoC_ADC/demo_batch under the Demonstration folder from ...
SreekumarR_G_Intel
7 years agoHello Stefano,
Can you check soc eds installed in the windows ? Can I assume you are using the cyclone V ? if yes here is the link for to start with
https://fpgawiki.intel.com/wiki/SoCEDSGettingStarted
Note : Arria 10 or Startix 10 soc related file generation shall be used only via linux OS.
Thank you ,
Sree
