12 years agoCapture image from video streaming by D5M camera
Hello, I am streaming video using D5M camera module. I want to store an image at a click of any key. But i am wondering, how to get the pixel location of streaming pixels. My Algo: I ...
12 years ago --- Quote Start --- What is the best way if I want to process the streaming video using NIOS. How can i get the whole video frame from the streaming protocol to the NIOS core and after processing transmit it further in the streaming protocol --- Quote End --- Again, I'm not familiar with the IP you are using so this is a general reply. You need to use or create an IP block which can receive the video frame and store it in RAM so the NIOS can then access it; and then perform the reverse operation of taking the result from RAM and supplying it to the stream. For example, if your system were using Avalon-ST you might be able to create a workable solution using the SGDMA in Stream-to-Memory and Memory-to-Stream modes.
