14 years agocan't seem to get Nios 2 to work on my DE1
I am having a problem getting the NIOS 2 program to download to my DE1 board. I've tried on two separate systems. One uses win xp and the other win 7. I'm logged on as Admin on both. I'm using...
14 years agoI am getting message :
Downloading ELF Process failed. I also see (in red) a list of things like 2) If -Stop is specified ... but it is gone too quick to read. I am just trying the example Hello World program. With v11.1sp2 I (eventually) got it all working, and was able to download and run Hello World ok. So I know the hardware is OK. Other details : I had problems with the default programmer : Attempt to access JTAG server - internal error code 82 occurred. I had to install v12.0sp2 standalone programmer, and now the .sop programming seems to go fine. But not the .elf programming - this was with the "Media" processor and "Hello World" program. Using a Win 7 64 bit system. cheers, Beau More info: I also have a DE0-Nano : I have loaded this with a simple non-floating point "Basic" processor, and this then programs the .elf and runs fine : Hello from Nios II! OK, now I will try the "Basic" processor on the D1 .... And now, for DE0-Nano and DE1, for both "Basic" and "Media" processors, I get : [Target Connection]: No Nios II target connection paths were located. Check connections and that a Nios II .sof is downloaded. The .sof seems to download fine. AHHH : one needs to update the processors (possibly etc) for v12 Go to the Atera University program, and download v12 : Hello from Nios II! on the DE0-Nano ("Basic") and DE1 ("Basic" and "Media" processors.) Happy times !
