11 years agoCan de0-nano work with high speed ADC (such as AD9283)?
Dear Community, I'm working in a wind meter based in DE0-NANO development board and NIOS II. Here's a basic block diagram of project: ultrasonic signal 1 (total length of 1000 us) -> ad conve...
11 years ago --- Quote Start --- Regarding your suggestion, actually my approach was to sample a reference signal (signal 1) then a delayed signal (signal 2). After cross correlating both signals, the result will give me the difference of time between the pulsed ultrasonic signal. When there's no wind, it's expected to measure a fixed delay. However, when there's wind, the delay will be changed. When the wind is around 1 to 2m/s for example, this delay increases/decreases of about some nano seconds. That's the change of time I need to measure, since this measurement will end in the wind measurement. Therefore, I'll study to write a vhdl code where a counter starts at the moment I excite an ultrasonic sensor. In parallel, there would be another vhdl code tto read ADC then, after the data gathered is over a trigger, then this counter stops. In this case, I would not be using cross correlation algorithm. In every case, I'll study Signal Tap to check what this tool can help me. --- Quote End --- Do you get to control the ultrasonic source and signal? Since you indicate you plan on sampling both a reference source and the echos, I would guess not. Your transmit pulse will have a much higher amplitude than your echo, so you will need to make sure you have the gains between the two channels set correctly. What do the response echos look like? If they are noisy or have multi-path signals, you may require some additional signal processing. How were you planning on cross-correlating the signals? Using lag correlation, or FFTs? Cheers, Dave
