18 years agoC Programming with Audio IP Cores
I am trying to take an inputted Audio file and trying to save it to the SDRAM (ie recording a word said into a microphone to the memory). My system uses a DE2 board with a Nios II Processor and...
18 years agoWell I found out what the problem was and it was basically my stupidity. When building the hardware, not all the pins were connected so you may want to check to see if the PIN map is correct.
