18 years agoC Programming with Audio IP Cores
I am trying to take an inputted Audio file and trying to save it to the SDRAM (ie recording a word said into a microphone to the memory). My system uses a DE2 board with a Nios II Processor and...
18 years agoI'm having the same problem as well, even when i configure it to avoid the bypass mode. Also, I can't enable the fifospace. When i try to write to the audio, the fifospace is always emptly.
If anyone can help it would be great.
