18 years agoBuilding serial communication...
Hi, I am using a FLEX10K UP2 board and want to do some image processing on it. I would like to build an 8-bit internal RAM for my FPGA in order for my design file to write data to the RAM and r...
18 years agoHi,
If you don’t stick to serial communication, you can use In-System Sources and Probes to read and write a FPGA internal RAM. http://www.altera.com/literature/hb/qts/qts_qii53021.pdf This tool provides a kind of parallel I/O ports resident in your FPGA. You can control the I/O ports through a JTAG cable and a TCL script.
