Beginners question in multiple assignments to output
- 3 years ago
What you seem to be asking for is analog logic, summing the levels on two wires to produce an output signal that can have three discrete levels.
IE: (0,1) + (0,1) = (0,1,2)
This is not possible in digital logic FPGAs.
At best you could two outputs and resistors to simulate a simple digital to analog converter, much like some development boards support an analog VGA signal using an array of resistor values R-2R-4R-8R etc to make a simple D to A.
Can't be done internal to a device however. Not with any current Altera FPGA parts AFAIK.
Dear SyafieqS,
I have already reply in my post on November 11 that ak6dn solved the problem. The problem is already marked as "solved" in the feed, but somehow I cannot put any kudos to this user for the answer provided (I do not why it does not work).
Thank you again for your help and support.
Best wishes,
